E.J.Whiley Build
Hi everyone,
This weekend I started working on E.J. Whiley. It's been a little while since I've built one of Brett's kits and even longer since I've done a build thread. For this one I'm sticking close to Brett's color scheme only a little bit more subdued.
3006n2_result
IMG_3138_result
I grained and stained all the wood. For this build I stuck with plain old A&I for all the boards instead of chalk and alcohol.
IMG_3139_result
The assembly method for this kit is the same as most of Brett's, board on board over a laser cut cardstock sheet. I painted all the wood with Apple Barrel Khaki using the wet brushing method. It always feels like it will take a long time to do the board on board but I covered all the walls in about 90 minutes.
IMG_3141_result
I assembled, painted and installed the windows and doors. The windows, doors and trim are all painted with AK Interactive Anthracite. I applied the paint to the doors and windows with a torn makeup sponge.
IMG_3143_result
One of the other walls assembled with the corner trim.
IMG_3142_result
All the walls are assembled minus any details and some additional weathering. I did 2 washes of A&I over the siding to darken it a bit and it caused some warping, so I had to add a bit of bracing to straighten it out.
That's what I have so far, next will be some more wall detailing and then gluing them together.
«13
  • Awesome, so very glad you see a build from you Steve!
    Love the walls and the toned down colors, very well done.
  • Great woodworking!
  • Great looking so far. Looking forward to seeing what you do with this.
  • Great job on the grain coloring. Hope to see more pictures as this comes along.
  • Hey Steve, great seeing you at the bench with a SierraWest kit again! Really nice to see this kit being done up so well. Love the colors you're on to...working perfectly. Walls are looking superb and will be following this build closely, love this seldom seen kit being worked up.
  • The color works
  • I dug a little deeper into the kit over the last couple days, it's starting to come together.
    IMG_3148_result
    I glued the walls together.
    IMG_3150_result
    I colored the stone walls and added the windows and doors. For the stone I primed it with gray followed by a couple A&I washes then I colored individual stones with various earth tone chalks. I added mortar using plaster darkened with brown and gray but it was really loud so I used some 408.3 to tone it down a bit. The windows and doors were colored with Reaper Boxcar Red.
    IMG_3151_result
    IMG_3154_result
    I glued the stone walls together.
    IMG_3155_result
    IMG_3158_result
    Both buildings mocked against each other to get a feel for how they will look, also making sure my fit against the main building is tight.
    That's it for now.
  • Looks great Steve. I really like the stone walls. Personally I like a very subtitle color variation in my stone work exactly like you have here. I’m not a fan of big variations in color. It works very well with your walls as well...
  • I really like the stonework
  • Thanks Ken and Bryan.
    Ken, I originally had some obvious mortar in the cracks and pretty heavy variation in the stones, but it really looked wrong to me. It was looking like a paint-by-numbers stone wall, so I kept weathering and blending until I got here.
  • the two look excellent side by side, and it looks like a nice fit where the stone walls join the main building.
  • The extra effort looks great on the stone work.
  • Thanks Kevin and Emery!
  • Steve wonderful on the walls. And the stonework a perfect match and coloring for the walls.
    This will be a perfect fit on the RR!!
  • Looking great, Steve
  • Looks great so far! It's wonderful to see this older kit getting some attention.
  • Thanks Jerry, Terry and Brett!
  • edited February 22
    Build is coming along great Steve, I always liked the looks of this kit, something about the angles always grabbed my attention...
    Stone work looks great,
    I really like your 'cold' stone colour contrasting the 'warm' (boxcar red ?) on the doors and windows, looks great, the stone combined with the not so easy to do weathering on that red, very nice.
    Nicely done so far, I'm looking forward to more.
  • Thanks Karl, you are correct the doors and windows are done with Boxcar Red but the Reaper version not PollyS like the instructions recommend. I agree about the angles on this kit, I'm always drawn to structures with a good variety of building materials as well so that might be it for me.
    I'm working on the roofing now, so I'll have another update in a day or so. Nothing much of interest to post while I add shingles.
  • Over the last few days, I the basic roofing done.
    IMG_3175_result
    For the stone building I did individual shingles instead of the included shingles with the kit. In the past I've used cedar sheets cut down into strips, split, colored etc.. but I found myself struggling to get them to a gray color that I liked. This time I used used HO scale 1x6s and chopped them up on the chopper after staining them with A&I. I did another coat of A&I after they were glued down and a little light tan dry brushing.
    IMG_3176_result
    IMG_3177_result
    I also did the rolling roofing for the main structure. It was primer with Red Oxide Rust-Oleum and weathered a bit with chalks. I'll add some more weathering once I got the roof details in place.
    IMG_3178_result
    The other side view.
    That's all for now. I started the decking and I'll be adding the roof rafters, door hinges and some wall signs next.
  • Really nice roof work Steve. Love the shingles! Evolving into a beautiful piece.
  • Shingles look great. Worth the extra effort.
  • Shingles turned out GREAT as did the rolled roofing.
  • Good job Steve. Really great work on the shingles. The color looks very nice.
  • Looks great Steve!!
  • Looking great. I like the colouring on the siding and the shingles.
  • Thanks for all the positive comments, everyone!
    I'm a little slow working this build, I'm not super motivated with the modeling lately. I did make some progress on the kit over the last week or so and I started to map out it's home on the layout.
    IMG_3184_result
    I started adding some details to the 2nd story porch.
    IMG_3185_result
    More porch progress..
    IMG_3186_result
    IMG_3192_result
    The roof is in place. It was a little bit tricky to get right but not as bad as I thought it would be.
    IMG_3194_result
    Patched in the valleys and the peak.
    IMG_3198_result
    I weathered the porch roof a bit to match the rest of the roof.
    IMG_3199_result
    Next step before I could move forward was to figure out exactly where this scene will live on my layout. I don't have any more siding space so this one will be serviced by the road.
    This is the little area that seems to work the best for it.
    IMG_3200_result
    Another shot showing the place from a different angle.
    IMG_3201_result
    IMG_3202_result
    It will sit next to my combo O'Neills/Quincy salvage and I plan on continuing the cobblestone road across the front.
    That's as far as I got right now. I started working on the road, once that's in I'll run the track that connects to O'Neills and start building the scene.
  • It is looking good Steve
  • Steve things are looking good. Why could you not use the track to O'Neills not also service Whiley's ? It was a shame to cover up the details on the porch with the roof.
  • It looks right at home there.
    I wonder how one of the roof patches would look in black.
