Machine Shop. AKA D. Elwell's Milling
Good Afternoon Everyone.
Well I have decided to build this kit and change it into a wood milling shop. I bought it on E Bay with some parts missing I knew that when I did buy it.
I have always built everything by the book but now that I am older I am going to do one my own way, I have a lot of milling machinery so time to use it.
Here are a few pictures of the build so far.
Tools that I used for the wood color and texture.
P1000327
P1000328 (1)
P1000335
P1000334
P1000340
P1000341
P1000353 (1)
P1000371
P1000369
That is all for now back to the stone work...........Carl.................
«13456
  • You've been holding out on us. Off to a nice start here.
  • Holding out for sure!!! nice start on things.
  • Looks like a great start to an interesting project! Looking forward to more Carl...
  • What are the stones made out of?
  • Looking forward to this build. Looks great so far.
  • Hey Carl so that's what you've been up to! I guess after the snow melts there's nothing to do until the grass grows!!
    That is lookin fabulous so far nice stone work to.
  • Hi Petet. They are made out of plaster.
    Thanks for looking Guy's.
  • Great job on the walls. Different coloring on inside and outside of the walls which would be prototypical. Your stones are well done. It must have taken quite a while to cast all of those. Great job.
  • Tom. I bought the stones on E Bay they come from Hungary After the wood is cooked I use a palm sander with very fine sand paper 220 grit and sand off the one side..Carl....
  • The stones are in place now have to do some adjusting before I put the grout in. So this is where I am at this point.........Carl............
    P1000387
    P1000385
    P1000385
    P1000378
    P1000382
    Some windows tomorrow then I have to make the base.
  • everything looks great carl, tho it appears that the top trim on one of the windows isn't level. probably an indication that the right trim piece is too short. otherwise it's absolutely perfect. the variations of the boards looks excellent.
  • P1000384
    Missed one.
  • Great spin on an old classic! Wow, doing your own stonework, can't wait to see how it turns out.
  • Here are two shots of the wall first one shop light second LED warm. ............Carl........
    P1000392
    P1000393
  • I like the lintel beam above the door. To my eye it looks like the stone lintels above the windows aren't supported properly and could potentially fall in. A lintel beam above the windows might break up the look a little and make them feel more supported. Just my thought. I do like the individual stones.
  • Tom. Thank's I am going to frame it out with some strip wood the stones were all the same size so either have two with a joint in the middle or what I have now I an going to work on it.
  • Carl,
    Framing the windows will help.
  • Well I messed with it and some of the stones became loose so I used Mat Medium and had shine spots then put on Dull coat and it darkend up everything so I am going to try some thinner and see what happens.
    P1000396
    P1000397
    P1000394
    P1000395
    Later ..Carl..
  • I tried to lighten up the stone work.
    P1000399
    P1000403
    P1000401
    P1000400
    P1000402
    Later ..Carl.......
  • i really like the lightened version alot.
  • Thank's Kevin.
  • Yes the lighter version is much better.
    Great job Carl.
  • Thank's Jerry and Ed.
  • looks great!
  • Thank's Boss.
  • Yes the lighter version looks better. I like your steel lintels. It anchors the windows.
  • Very, very nice Carl! Love the window screen.
  • Thank's Ken.
  • Well the walls are up now time to make more...........Carl...........
    P1000404
    P1000405
    P1000406
    P1000407
    P1000408
    P1000409
    P1000410
    P1000411
    P1000413
    Thank's for looking.
  • Hey Carl, This is coming along very nice
