Since 3D Printed castings are fragile with the incredible prototypical detailing, I developed this super easy chipped paint technique. I am working on several new videos but wanted to post this quick sbs. This is specific for water based paints. A dark base (like black!) is very important as you need a contrast between the base and top coat. I use a flat spray paint as my base.
This works great anytime you want chipped paint effects for oil drums, gas bottles, trash cans, etc...
Paint your casting using the same techniques and water based paint as you would my traditional hand poured resin castings then immediately dunk the entire casting in isopropyl alcohol (ipa). You can leave it in the ipa varying lengths of time depending on the desired effect and brand of paint. (This will be demonstrated in the video btw.) Try "sloshing" it around too, some neat results will occur. Experiment to see the different effects you can achieve. Super easy!
Pull the casting out and using a cosmetic foam wedge, gently roll the casting against the wedge or tap/blot the wedge against the wet paint. This is lots of fun and simple. Allow to dry then chalk weather just like the hand poured resin. Try layering the paint and chipping each layer allowing the layers to dry each time. Use different colors for really neat effects.
The wedges are easy to find and inexpensive. They can be reused many times. I believe I purchased this bag at target for like $5 a few years ago.
Have fun and enjoy!
George
Anyone have a good dead flat black rattle can brand?
I've actually been using a dark gray primer instead of black lately. Seems easier on the eye. It's Rustoleum auto primer.
George
I tried it for the first time while building the Case. I wanted 2 tone black on the boiler. Used flat black and this. Really liked it so I use it more than black now.
1- When the cans are empty always take off the good nozzles and save them as spares to swap out with one that spits or clogs.
2- When you finish spraying but still have paint left take the nozzle off and soak it in paint thinner, I usually use xylene as its stronger and will also clear a clog.
3- If you have a can with no paint in it but still has propellant in it put the dirty nozzle you just used on that can and use that empty to blow the nozzle clean.
Turning a can upside down and spraying until clear wastes both paint and propellant. I have several half full cans with no propellant left in them, so switch your dirty nozzle to an empty can and use that to blow it out.
4- I have a small empty garlic jar with xylene in it, when finished spraying I throw the nozzle in to soak, leave over night and with the lid on shake it to dislodge any clogs.
5- If you have a half full can with no propellant in it or a clogged stem you can decant the paint out into a small jar or bottle and use it to either air brush or brush on. There are several YouTube videos on this
Seems no matter what I do they still clog up. I'm lucky to get thru ⅔ of a can... Gonna try the soaking cap in Xylene. Only done that using paint thinner and no go - most eb too weak a solvent.
