Another BEST 60 build: JimM
edited December 2023 in O Scale Builds
I've been slowly plugging away at this kit.
I first laid it all out to take inventory and take it all in. Inspecting the picture, I notice that I inadvertently left the "control cluster" out of the picture (oops, sorry Brett). Also note that the instructions for this kit are available for download on the SWSM site.
IMG_1958
I've looked at hundreds of pictures and watched many videos of this crawler before deciding how I wanted to proceed. I decided I wanted to somewhat mimic this prototype. I will incorporate a few changes to the paint scheme but this is essentially what I am trying to reproduce.
BEST 60 prototype2b
I want to start with a bare metal base so I will prime all the parts with a Rust-Oleum Metallic "Matte-Nickle" spray paint.
IMG_1960
By the way, this is my spray paint can mixer, it works great. If anyone is interest in the parts to build, hit me up in a message.
IMG_1961
I then hit all the parts with dry black chalk. I think this gives a nice "tarnished metal" look.
IMG_1963
IMG_1965
If anyone is wondering if the 3D parts can be made to look like the old white metal parts, I think this technique is spot on. The piece on the right is white metal after it has been blackened and buffed; not much difference at all.
IMG_1975
I wanted to try the "hairspray/salt" weathering technique, so I started by putting some rust spots on the various parts using some craft paint colors.
IMG_1974
IMG_1969
I then spray hair spray over the part and then apply salt over where I want to later expose the bare metal or rust.
IMG_1976
IMG_1977
I then masked off the radiator, and then painted the entire main assembly and the front and back of the tracks with a Reaper "Concrete Grey" color using an airbrush by thinning the Reaper paint with a few drops of distilled water. After the paint dries, I chipped some of the salt off and I used warm, soapy water and a light brush to remove some of the paint in strategic areas so that the rust and bare metal show through, it give a bit of a chipped paint effect. This picture was taken after some additional chalking was applied.
IMG_1992
I wanted to go with the red track so I masked of the inner part of the track, sprayed more hairspray onto the track, let that dry a bit and then airbrushed a thinned Reaper "blood red" onto the track.
IMG_1979
After the paint dries, I again used warm soapy water to remove some of the paint off of the track down to bare metal. Once dry, more chalks to dull and weather.
IMG_1994
I then used the same hairspray/salt technique on the main body. After drying, I applied a lot of weathering chalks. I used the tip of a sewing needle to apply paint to the lettering on the body and the radiator. I painted the seat black and I painted the "doghouse" for the flywheel the same blood red color.
IMG_1982
IMG_1983
IMG_1984
IMG_1985
Moving on to the roof, I cut the corrugated sheets with the template and punched the hole for the exhaust with a leather punch.
IMG_1980
I then spray painted the corrugated sheets and baked them and that's where I am right now. I should be able to finish up this wonderful kit tomorrow. I'll post the finished product when done. Thanks for looking.
  • What an awesome build so far - and thanks for all the great, detailed pics! Can't wait to see the completed sixty.
  • Thanks Brett, great kit.
  • Wonderful work thus far Jim! Shaping up to be a top shelf build.
  • Thank Ken, much appreciated.
  • Great tutorial and fantastic work !!!
  • It looks very good.
  • Great explanation of your techniques. Looking good!
  • Looking good Jim. Going to steal your idea of using the leather punch!
  • Great work on this Jim. Thanks for taking the time on the tutorial. I does really help.
  • Thanks guys, I appreciate the comments. I've never done the "hairspray/salt" method before, and I am satisfied with the results. I made a few mistakes in the process, but I learned a lot that should aid in the future. I'm glad the step by step is somewhat helpful to others.
    Travis, the punch idea is right out of the instructions so no need to steal.
    I epoxied the control cluster and fuel tank and the upright supports for the canopy in place. I then glued the purlins for the canopy to the upright supports. Paying attention to the position, because the hole I've already punched in the corrugated aluminum for the exhaust has to line up to where it goes in the engine, and I wanted the purlin to come to the front of the canopy. The included purlins are a little bit long so it gives you a little wiggle room that they can be trimmed after the canopy is applied using a straight nail cutter.
    IMG_1995
    I then, chalked, weathered, sooted, etc the roof and glued it in place.
    IMG_2009
    All that was left to do was a little painting, I tried to add some oil and grease to the track rollers, tried to dirty up the engine under the frame a bit. I also added some dirt chalk to the tracks. I chose to not glue on the hitch as yet because I'm saving to do that if I need to tow something specific and need it at a specific height.
    Here's the finished product.
    IMG_1996
    IMG_1999
  • beautiful example Jim! What a nice project. Was this the O Scale version or HO?
  • Thanks so much Ken. O scale.
  • That's outstanding Jim. Dirt on the wheels is present but not overpowering.
    I think the light gray gives more options when it comes to weathering as opposed to the black. I do like the black with red tracks and gold letters scheme though.
  • Thanks Brian, I appreciate it.
    " I do like the black with red tracks and gold letters scheme though."
    It was a flip of a coin. I really like that paint scheme too. Maybe the next one.
  • You said that you wanted a used tractor but nor worn out. I would say that you accomplished that goal. Great looking model. Randy
  • Fantastic modeling Jim, colouring and weathering are superb.
    Beautiful work on a beautiful print.
  • Thanks much Randy, I appreciate that.
    Karl, thanks, Brett created a very nice, fun kit.
  • Turned out very nice!
  • Jim,
    Awesome. Great build and tutorial. Thanks for sharing.
  • Very nicely done...the tones are right on...
  • You out did yourself Jim. This is so very cool!!
  • Thanks Tom, much appreciated.
    Dave, thanks so much. I don't know about it being a tutorial, more like a "what I did". I've never used this technique before, but I think I'm happy with the result. I hope to improve in the future.
    Art, thanks, I'm looking forward to seeing your finished product as well.
    Thanks Emery, it is a pretty cool kit.
  • Outstanding work great color as well.
  • Great work. I love the colour and texture of the track wheels and sprockets.
  • We’ve got several of these builds going on in the Forum. They’re all individualized and well done!
