Request Critique on My Shipyard Build
edited January 2014 in HO Scale Builds
Yesterday my Shipyard arrived. I have never built a craftsman model. With your kind indulgence, may I please post my work and receive critiques? I have read the excellent build logs here on the forum and plan to use them as supplements to Brett's manual as I go along. I have read substantially everything here in the SW forum as well as a great many of the build logs on the 321 pages of the Rail Line forum. As Brett says, "Its time to get your fingers dirty" I am going to post only one photo now to be sure I am following Bill's instructions on method and file size - less than 200K.
John Maguire
Seattleimage
«13456713
  • Seeing that the text and photo of my first post were almost correct, please allow me to advance to todays initial tasking for which two questions arise - paint and chalk.
    In accordance with Brett's instruction I painted the roof covering with my new air brush - which I've never used before. It is an Iwata Custom Micron gravity, dual action, 0.23 MM needle, etc., etc.
    I have watched a number of videos on usage so I began by running cleaning fluid through it into their cleaning jar a couple of times and setting air pressure at 18 PSI. I have the Iwata paint called Medena which supposedly requires no thinning. I began my initial spray experiment on a paper towel and it seemed OK - except as I was painting, eventually I began to get occasional paint blobs which you will see in the photos below. Going back to the paper towel, less pressure didn't seem to help and more seemed like too much, though I certainly need to practice with the dual action. Could it be that more pressure but less pull on the trigger would help? I also tried thinning the already thin paint and that didn't help. When I cleaned the brush at the end of my work I thought the needle tip looked gummed up and that might have been the issue.
    My chalk work doesn't look nice. I thought a variation would be good but perhaps there is too much. I am posting an overall photo to show that followed by a close up to show detail.
    John Maguire
    Seattle
  • edited January 2014
    Welcome John, happy to have you posting here. We are a very polite bunch but will tell it like we see it... straight up. I'm gonna dive right in here with an opinion:
    I hate airbrushes. Nothing personal but they need to be cleaned are are really fussy. A good old can of spray paint from walmart works better for this type of modeling. With that said your tarpaper will be fine once weathered and installed.
    I really like your mottled coloration on the wood. Great variation and perfect for a waterfront but I am not in love with the white flecking. Gonna have to see it installed on a wall to really judge. I believe the problem lies with the pastels you are using. The Girualt sticks are cake like and firm. They produce shavings. The sticks I prefer as outlined in the manual are like children's play chalk and powder better.
    Glad you have the balls to be here John and stick with it!
  • Brett: Don't forget, I asked to be critiqued. I know nothing! I don't expect to be doing anything correct. Watching others do it in their build log and doing it myself I just learned are two very different things! But we all really know that, don't we?
    Thank you very much for your comments. My chalks are Rembrandt - 408.3 for the initial and I think the white is 100.5. Aren't those what you want?
    The 408.3 gets washed in with the alcohol but as I understand the manual the white just gets flecked on so it ended up laying on top of the wood. It doesn't look right to me. It'll just fall off.
    The kit is a work of art - you are a Wizard.
  • Glad you using the rembrandts - be sure to watch the video on my website:
    http://www.sierrawestscalemodels.com/video/video.shtml
    It was filmed during the construction of my shipyard pilot model... No white flecking involved!
  • Welcome John, great to see another shipyard build getting started, I'll definitely be following along.
    I agree with Brett regarding the spray cans,
    pick it up, shake it, spray it, put it down, ....... nice and easy.
    I look forward to more progress.
  • Brett: Thank you, yes I have watched your video. I believe I have seen everything on this site, both tutorial and individual logs.
    Karl: Thank you for your comment. I really admire your work.
    I would initially like to post more mundane detail than is normally shown because I need guidance on technique. Watching you folks do it and getting my hands dirty alone are somewhat different.
    I believe the reason the white Rembrandt didn't dissolve on contact yesterday on the planking is because the alcohol dried too quickly. I am using the same 70% you all do. Perhaps I didn't get it wet enough to remain wet until chalking. Does that sound reasonable? Today, I minimally wet my brush and ran it over all the planks to cause the white chalk to dissolve and meld. Photo below for comment. It certainly greyed the wood in uneven streaks.
    I put an extremely light coat of paint on the shingles. Is it too little. It doesn't seem like enough to me. I am attempting to err on the side of not enough so that I can add if necessary.
    The etched walls shown below have some grey chalk but it isn't too noticeable. Am I correct to think this is only being done so that unpainted surfaces won't be visible between cracks in the wall.
    Shingles and walls are embedded in a large thick heavy book now for "attitude adjustment".
    John Maguire
    Seattle
    Starting at the beginning is the best place. Nothing is mundane, it is the prep work and the base layers that support the finished product. I'm a professional painter and I know how important prep work is. Finish coat can be perfect, but, if it's sitting on crap it will look like crap.
    Chalks should be applied to the wood and then washed in with alcohol on a brush thus creating a stain.
    I put an extremely light coat of paint on the shingles. Is it too little. It doesn't seem like enough to me. I am attempting to err on the side of not enough so that I can add if necessary..
    You took the right approach, it is always easier to add more colour later than to try and remove it. I would let them dry and put them to one side until later in the build when you need them. Once you are ready to use them you can evaluate the colour then next to the walls.
    The etched walls shown below have some grey chalk but it isn't too noticeable. Am I correct to think this is only being done so that unpainted surfaces won't be visible between cracks in the wall...
    Correct. Small steps like this make the big difference.
    Show them who's boss....
  • Thank you For your time Karl. I'm loving your build. The coloring is spectacular. Your comments here are very much appreciated. On to some glue and sticky fingers now!
  • Wood looks much better now John. When I was reading down through your posts, and saw your initial application of the white, I was getting ready to respond that you need to wash that in as well, but you thought it through and made a simple adjustment that greatly improved the outcome. Also one other thing you may want to try is using 90% alcohol - I find it creates less warping. I will be following along on your build - great start John!! Cheers.
  • Thanks for that Woody. I am on to my first glueing of planks but am going to recheck Paul, Marty and Mikes work before getting my fingers dirty.
  • I glued my first wall sections today. A family member has promised me some steel pieces similar to Paul's copper but I don't have them in hand yet so I have used my heavy glass plate. The locating holes in some of the walls were a great aid.
    I put knots into some planks but am unsure how many I ought to prepare. In this instance I adjusted the toothpick to be flush on the finish side of the plank and glued on the opposite side so that I won't have to do any sanding and remove stain and color after the glue dries.
    As a preamble to starting this project and also the construction of some O scale brass British railroad stock I modified a little used room and built a table that I hope to be wide enough to be able to have two different projects going at the same time. You'll recognize Paul's build log on the computer screen.
    Critiques are solicited and will be welcome. I notice my plank coloration looks more gray than what Paul has done. I like his woody look. These pictures are taken in natural light on the north side of my home - to understand the lighting is part of why I wanted to show my work area.
    The work place photo was taken from the area of the most comfortable chair and hassock imaginable! I can model a little then sit back with a glass of wine and enjoy the ambiance. Life is good . . . .
  • Damn John. That is a pretty view from your bench.
    Make sure your walls are straight after the glass of wine hey. HAHA
  • Hi John, welcome to the forums. I'm really glad you're building the Shipyard. You can only read and watch so much before you taking the plunge. When I'm unsure about a new technique, I usually try it out on scrap pieces (like the Shipyard sign and applying strip wood to the walls of the warehouse on my build), this usually helps perfecting the techique.
    Looking forward to following along with your build.
    Paul
  • Wes, I'm pleased to see the glass of wine elicited a response. I used it to do my initial admiring inspection of the kit!
    Paul, thank you for taking time to comment. I have so much to learn from your work, My steel blocks are complete and I think I'll have them on Saturday. I'll photograph them to show you. What a great idea you had . . . yes, I immediately found that "doing" isn't the same as critiquing the work of another. There are so many great techniques to be learned from here and the Rail Line that it is like trying to drink from a fire hose.
  • Yeah John a glass of good red is a must when opening one of Bretts great kits.
    Looking forward to more of your updates.
  • Hi John-
    Good to see another modeler jumping into the world of Sierra West!
    I'm a bit late to the party and you've been given plenty of solid advice.
    Having not built the Shipyard, I've only lived it vicariously through Paul's build so I can't offer too many specifics. But I've got a couple general suggestions:
    Like Woody, I prefer using 91% alcohol (it has less water so it dries slightly faster). 70% is made up of 30% water as opposed to the 9% water in the stronger stuff. No need to stop using the 70%...I mention it only so you know the difference.
    When I use chalk to stain stripwood, I flood the wood with alcohol. LOTS of it. So much, in fact, that when I flip the strips over the back side is also colored quite a bit, if not entirely. See the picture from Jan. 20 above where you're showing us the knot holes? In looking at a few strips I can see that the color hasn't seeped all the way around onto the backs. Using more alcohol is the cure. In turn, you'll get of the unevenness. You want variety, but that comes from using more or less of a chalk color. Wash it in real well with alcohol.
    Your work space is terrific! Gotta love having that 27" Mac monitor close by.
    Perfect view, a glass of wine, a Sierra West kit...that's the making of a relaxing afternoon!
    Looking forward to more.
  • Oh Bill, you are one of my heroes. I've been hiding out reading this forum for a year so I know ALL about you! Thank you very much for your comments. Congratulations on "First In Show". Wow . . .
    Yes, on the knots. Actually, as I bet you can surmise with your practised eye, I put them in after the staining. I noticed in one of these build logs (so much information creates an overload of who has done what - then I add to my overload by reading Railroad Line) that someone put knots in a third of their planks, so with that possible objective I've got a ways to go. Bill, I can see the logic of a heavy dose of 90%. Doing that would have kept my planks from having flecks. My planks are stained now to the extent of my novice ability. Once I add knots to these already stained planks, please tell me how to deal with the fact that I seem to need to start all over again with them. At the same time, I believe I might need to get a courser wire brush (Sunday morning) and beat them up some more.
    Thank you all of you Wizards for looking in and offering the suggestions that I have prayed you might by starting this thread. I have high standards without matching ability - but with your combined guidance I'll get where I want to go!
    John Maguire
    Seattle
    ...............then I add to my overload by reading Railroad Line) that someone put knots in a third of their planks, so with that possible objective I've got a ways to go.......
    John Maguire
    Seattle
    That would have been me John... had you remembered that it was me then you could of asked me about my new little twist on the technique which allows you to perform the task four times quicker, meaning, you will only spend 1/4 of the time drilling all those little holes. But alas.....
    As for your staining of the wood, Brett and I were discussing only the other day how good it came out (after you had washed in the white), and noting the great tonal differences and colours in the wood. So, I'm not sure why you think you need to start all over again. Unless they look vastly different in person than on the screen, which I doubt.
    Looking forward to updates..
  • Oh, oh Karl. I thought about keeping a file on all the hints I read but for various reasons that hasn't worked well for me in the past so in lieu of that I have opted to occasionally spend some time reading the major build logs and pick up tid bits that way. Before reading this post that you just wrote I went through and knotted about a third or more of my planks the hard way.
    I thought my planks lacked texture compared to the work of the rest of you so this morning I bought a large steel wire brush and after getting a third of my planks knotted, I beat them up (knotted and unknotted) with the new brush, 408.3'd them and gave them an alcohol wash to work it in. That gives my knots some color - I did ALL of my planks however so that there would be some continuity. I need to let them dry so tomorrow I'll photograph them and request comments. I learned that a small amount of white chalk causes them to dry a very silvery gray rather than the woodier color from the 408.3. I don't think I see other builds having the buildings looking silver gray. Opinions anyone?
    Part of the reason for showing my work area is demonstrating that I have north side natural light for photography, so the color in pictures might be reasonably representative.
    I observed that when I wire brush, a whole lot of the color tones remain but the texture is improved. Conversely, brushing with alcohol appears to fill in the texture. Brett says brush each plank prior to glueing in place - I see why. Presumably, following his instruction to then dab some chalk onto the alcohol wet plank will preserve the texture. I need to develop that technique so that I am not backfilling the texture.
    Thank you all for being so patient with this. I need you all to keep on me so that my work meets my expectations.
  • I have done several builds with silver grey walls also John, I like the aged look it gives.
    I'm interested to see how your wood is looking after these further steps.
  • Karl, et al,
    Well so much for taking pictures in natural sunlight, herein is a photo of my redone wood shown on a cloudy day. Since the tooth picks were untreated when inserted, never to be repeated, I wire brushed & 408.3'd all of them again. A couple of batches of five had 100.5 added and they noticeably grayed - I relocated those at random for this photo. If these colors are satisfactory, I plan to begin fitting and glueing my first wall. I am intrigued at how quickly the color tends towards a predominant gray with such a small amount of 100.5.
    I have an engineering mind not an artists so I feel totally naked wondering how to deal with what color. It is easy for me to see and like something but I can't create it - I need to copy it - that's OK because we all have different skills and we compliment one another. I have seen in redoing these planks that as soon as I wire brush them they will look different. Instructions say to fit a plank, steel wire brush it, wet it with alcohol, dust it with chalk and attach it. From what I have just done it seems that as soon as I wet, chalk and brush it I pretty much fill the texture. I am missing something in my technique for which I am requesting guidance.
    I have also attached a photo of my initial dozen "Paul" blocks . . . Being steel, I had to buff the oxidation, degrease them and then seal them with paint. I have an additional dozen on order.
    Comments on wood color and especially on the final brush, wet and chalk would be very much appreciated.
  • John, Really, really, nice. You got some very nice variation in color and texture...I like it. Those darker boards seem a bit too dark to me but still a great batch of wood. I think very well done
  • Well dear friends, herein is my initial attempt to plank. I lack an intuitive sense of what I am looking for as I pre-color the planks per instructions during the installation. Therefore my coloring that I added as I planked is haphazard and lacks a personal goal. It sure looks a lot easier when I watch you people do it . . . . My own intuition keeps telling me that the 408.3 is making the planks to dark and too gray but I am following instructions. Then when I add white it looks too white. I need a local artist! In so far as the boards that are too dark Ken, when I wire brush them prior to installation it seems to lighten them appreciably. I could deal with them being too dark on a plank by plank basis as I wire brush them at the time of installation.
    I may have interpreted instructions too literally as concerns plank spacing - there are some gaps.
    I am going to spend some time again looking at build logs for additional guidance.
  • Always remember that if the business is still "a going concern" the building will look worn not derelict. Depending on the latitude, the gaps will be okay or the workers will freeze.
  • I personally like your wood colours / contrasts. Remember not all buildings weathered the same nor were painted the same. You are allowed some personal preference here - no "right" answer where colour is concerned.
  • Alan: good comments - thank you. It doesn't look like colors others have done so it spooked me!
  • The boards are looking good John. If you still feel that some are a little too dark a light rubbing with some steel wool will take off some colour and lighten them back up.
    Remember with every step you are taking subtlety is the keyword.
    Also remember if you are happy with the board colour before you apply them there is really no need to do any additional steps. The colours look fine to me in the pic with the boards all laid out.
  • Thank you Karl - I'll continue with what I have then.
  • I have tried to combine Brett's instructions with the various advices received and here are my first attempts at texturing, coloring and glueing. Criticisms are requested please if any of you have the time.
