HO Truck Repair Shop
I am in the process of building the Railroad Camp, but decided to split the buildings up as I won't position them the same as Brett suggested. I actually started this last September, but had to move from Hawaii to South Carolina around the holiday time. Knowing that, I did not want to start a discussion with a huge gap or glue the walls together as they pack much better flat.framing
truck repair 2 edited
So I have progressed since getting unpacked and setup to model again. So far all is per the instructions. Here is a serious jump forward.
truck repair 10
truck repair 12
truck repair 16
I am taking things slightly out of order as I wanted to address lighting and the roof before I did all the outside details. I also decided to do real cedar shingles. I cut shingles from sheet cedar from Sierra Scale Models then gave them a quick soak in Hunterline Driftwood stain. Here is a couple quick shots of where I am now with the shingles. Haven't tackled the lighting yet.
Cedar Roof 2
Cedar Roof
Time consuming for sure, but I think worth the effort.
All comments and suggestions welcome.
Rick
  • Efforts paid off. Very nice.
  • Very well done so far. The colors are great, on the castings and the wood. Singles are looking good aswel. Nice work you show us here Rick.
  • Thanks Robert, Bryan and engine909. All your comments are encouraging. That's what I like about this forum. Of course there will be more weathering and blending as I proceed. Photos when I have more to show.
  • Nicely done Rick. Castings are painted and weathered very well. I like the real wood shingles. Certainly worth the effort.
  • Superb Rick! Everything is coming together so well. Can't wait to see more. Thank you for sharing your build with us.
  • Hey Rick, wonderful modeling and detail work! Really nice to see you posting your work here. The shingles are going up nicely and are giving the structure a great look. Following along closely...Ken
  • your wood tones on the walls and shingles is spot on. nice work!
  • Thank you Tom, Brett, Ken, and Kevin. All of you are very supportive. Here is the finished roof. A bit more weathering, but very little. I think I like it as is. Suggestions?
    What is interesting is how all the shingles were stained together in a single batch, but how differently they absorbed the stain. The broken shingles are natural as well. Very fragile.
    Cedar Roof 3
    The roof is not fastened down. Off to lighting and many more castings to paint.
    Rick
  • The roof color is very good. You might considder adding some moss at the edges of the shingles here and there.
  • I really like the roof. Robert is the master of moss on shingles. Check out his supply shed build for an example. You could also make a tarpaper patch to add interest.
  • personally i would leave it alone. it looks perfect as is....
  • Thanks guys for all the comments. Robert, you do phenomenal work and Bryan agrees with your approach while Kevin likes it as is. It is a personal taste issue. I am not modeling an area that is that moist. I do show some dry rot at the base of the walls though.
    Everyone's support definitely keeps me striving to improve.
  • Shingle color turned out great! I especially like the few broken shingle. Not overdone just right. Roof looks used but not neglected.
  • Thank you Tom and Ed. It is encouraging to get these comments.
    So, with staying home for obvious reasons gives extra modeling time. I wanted to add lighting to this structure. I decided the best was to add a beam down the middle of the building with a couple lamps on it. I drilled out a couple old lamp shades I had and used warm white pico LED's that are prewired ready to go with the resistors already in line from Evans Design. (There are other suppliers.) I used these as no magic is needed. Jost install, hook to 5-12v and you are good. The pico LED's are so small, they fit through the hole I drilled. The super small wire is run along the underside of the 6X8 beam. I then used Micro Kristal Clear to fill in below the LED and look more like a bulb.
    truck repair 21
    I chalked the wire to help blend it into the wood coloring. I ran the wire down the wall next to the cabinet and behind the tire leaning against the wall. Third photo down. You can't see it through any of the doors. Here are the results.
    truck repair 19
    truck repair 20
    truck repair 22
    Now to work on the exterior details.
  • edited March 2020
    lighting it up looks excellent. great looking model so far.
    i wish i had the balls to try lighting.
    i'm clueless.
  • The lights sure make a difference. Now one can see your nice work on the interior.
  • Great job on the lights. They always make a difference.
  • Lighting looks fantastic, really shows off your super wood weathering skills.
  • Sorry just cathcing up. The lighting adds a whole new dimension and showcases all the interior details. The roof is fantastic.
  • Well done on the lighting Rick. Makes those interior details feel appreciated!...
  • Rick, I don't believe we have corresponded since I've been off the forum for about a year. I like your build and have used individual cedar shingles on my previous build. A lot of work but very believable. With regard to the Evan Design lights, can you remind me again what resistors are required if you are going to use a 9 volt battery to power the lights. I know it will depend on the number of lights, but can you tell me the formula? Thanks. Phil
  • All the comments are very encouraging. It is good to hear from many I admire.
    To answer your question Phil, the LED's as I purchase them already have the resistor installed.
    Light 1
    Light 2
    They are prewired and ready to operate on anything between 5 and 13 volts DC. I shot the photo on the dime so you can see how small the pico size really is. Very simply the + or pos lead is the red and the - or neg lead is the green. I am amazed at how much light such a tiny LED can give off.
    Do power one up before installation so you can see which side needs to face down. It is not off the end like a standard bulb, but otherwise just too easy. Many are intimidated for the wrong reasons. It's the same as the first time you look at a SW kit. Dive in!
  • Light 2
    The second photo didn't post correctly the first try.
  • Rick, thanks that was helpful. Phil
  • okay, okay. i'm convinced. i'll give it a shot.
  • I am coming to completion on this model, but wanted to show the results of the lighting for those hesitant to try it.
    truck repair 65
    truck repair 66
    truck repair 70
    I'll post my final photos soon.
    Rick
  • Lighting always makes a big differences. You don't want to spend so much time on the inside castings and can't see them in the model. BTW, how did you hide/attach the wires to the light? Phil
  • Phil,
    Here are 2 photos showing angles no viewer should normally see. The magnet wire on the LED's is so small, a little chalk coloring blends it into the underside of the beam. Again, the viewer would have to look below ground level up under to see it at all. Where it runs down the wall is a fairly obscure location that is visible in the super magnified photo, but not where the viewer would normally look.
    Yes, I am posting photos that most would never show, (not pretty) but the question was asked.
    truck repair 80
    truck repair 81
  • A few final photos. All the interior has been shown above so just 4 outside to finish. Sometime in the future, I will look to add a truck in the bay, but that will be much later.When I am ready to integrate this into the layout, I will do more varied vegetation to blend it in and possibly a few more details around the outside. So for now, this will go into protective custody till I am ready for it.
    On to the office warehouse part of the Railroad Camp kit. That will be a different post.
    truck repair 72
    truck repair 75
    truck repair 79
    truck repair 78
    Thanks for looking.
  • Rick
    Looks awesome. What did you use for base, styrofoam?
